how to design a suitable vi to acquire ECG waveform?
To know how to design a suitable vi to acquire ECG waveform from the bio-amplifier board using LabView program.
Message 1 of 15
(6,130 Views)
Huh,
Here's a VI I wrote in school to acquire ECG signals using an NI DAQ board. Hopefully this will help you get started with your application. Have a great day!
Message 2 of 15
(6,136 Views)
Hi Sarah
I am intrested in acquiring and analysing ECG waveform .I was unable to run your vi. I have a 8.0 Labview version and a NI PCI 6259 card . Do i need to configure my PCI card to run your vi . Please advise me how can i view the waveform and analyse from the ECG vi you have already built .
Jim
Message 3 of 15
(5,850 Views)
Jim,
Your card uses DAQmx instead of the older Traditional DAQ driver that Sarah's code uses. I modified the code to work with your card and also converted it to LV 8.0.
Abhinav T.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
Message 4 of 15
(5,839 Views)
 Abhinav
i really appreciate your advise and help ,but even after connections i am not able to see the raw ECG waveform . Do i need any more drivers or do i need any more configration upgrade.Please do advise .
Jim
Message 5 of 15
(5,831 Views)
Jim,
I changed the code a little more, it seemed like the graphs were plotting black lines. You will also need the new DAQmx driver to perform data acquisition.
Abhinav
Abhinav T.
Message 6 of 15
(5,817 Views)
Abhinav
i really appreciate your advise and help , i was able to view the wave forms .Please advise me how can i view a clear wave form, i tried various combinations of frequency and sample rate still i am unable to get a clear wave form . Can you please aprize me with your settings if you are able to view a clear waveform .
Jim.
Message 7 of 15
(5,810 Views)
Jim,
I am not sure what you mean by a clear waveform. Can you elaborate with some pictures?
Abhinav
Abhinav T.
Message 8 of 15
(5,796 Views)
Abhinav
sorry i was unable to reply as i was on a leave,i shall be back to office tomorrow and will get back to you for any advise if needed. Thanks for everything.
Jim
Message 9 of 15
(5,749 Views)
Abhinav
Please advise if we can do signal conditioning by using a lowpass filter and then a band pass filter to the raw ECG signal .Will it improve my waveform ?
Jim
Message 10 of 15
(5,737 Views)
