07-02-2015 06:38 AM
hi, I want to get analog output from photodiode using ni usb 6008 using daq assistant and display in waveform graph.kindly give any suggestions.
07-02-2015 08:46 AM
So you are measuring the voltage? That would be an Analog Input. There are plenty of examples for DAQmx and how to set this up. Look in the example finder (Help->Find Examples).
07-02-2015 09:06 AM
And you migth need a TIA or photodiode current to voltage amplifier if you have the discrete photodiode.
