how to get the samples of the ni-9263 and ni-9201 in the same time?
Thanks for your reply.But,Why adding a new channel?Do you mean I compare these two channels of the input ?I guess It could be exactly synchronization.But,what does it stand for?
Message 21 of 36
(1,662 Views)
You are the one that is whining about the different timestamps and you are obviously comparing them. Of you don't want to compare them, stop posting and get on with life.
Message 22 of 36
(1,652 Views)
I want to get your help from bottom of my heart.But,you always said others than pure technique.If you had time  to say these words.Why you hadn't told me more technique?This time,I just asked you what do you mean?If you do not have time to tell me more detail.You can just simply say yes or no.Why you always say these.
By the way.You didn'.t answer my question.
Message 23 of 36
(1,649 Views)
if you don't understand, then I don't know how to make my explanations any simpler.
Message 24 of 36
(1,645 Views)
I already told you.Please correct the wrong place for me.It is simple for you.Isn't it?
Message 25 of 36
(1,639 Views)
If you don't understand this, then this will truely be my last attempt at getting this very basic concept explained.
Message 26 of 36
(1,629 Views)
It's very kind of you to send me this vi. but,My labview's version is 8.6.Could you please change to labview 8.6 vi?
bothered you a lot.
Message 27 of 36
(1,616 Views)
Thank you very much.I run your vi and was surprise to discover that they are not synchronization either.I don't want to bother you this time.But,I really want to know why.Would you like to tell me why?
Message 29 of 36
(1,596 Views)
If you right click on the graph and uncheck Ignore Time Stamp, the graph and file should match.
Message 30 of 36
(1,587 Views)
