how to measure the output voltage level of the Digital output?
When  I tried to measure the output voltage level of the digital output ( Po.0) by giving all 1s to all the lines of the digital port of the NIDAQ USB 6259, I am getting only .00001mV.So, please tell me if I am measuring the digital output properly.Also what will be the output volttage in NI USB 6259.(I checked the specification,wher I found  the value of digital output high is given as 5V )
Pradeep.
(3,913 Views)
Hi buddy,
It's possible that what you are measuring is just noise, try a self calibration test and see if that rectifies the problem.
If not what are you measuring it with?
Rich
Richard S
Certified LabVIEW Associate Developer
National Instruments UK&Ireland
(3,865 Views)
