how to short signal pin
please find the attached file where 2 connectors are mentioned.i want to short  OUT and IN pin of j5 without using realy and NI DO.how we can do these mechanism using different electronic component and labview.
(3,450 Views)
Accepted by topic author Risuraj
A relay is by far the simplest route.  What is your problem with using a relay?
The other route I would consider is a MOSFET.  But if you are going that way, you might as well just get a Solid State Relay (SSR).
(3,445 Views)
A small SSR controlled by a abused RS232 handshake line ?
Greetings from Germany
Henrik
LV since v3.1
(3,425 Views)
can i use opto-isolator(optocoupler)??how to control this one using NI c series module??can u suggest some optocouler for this implementaion?
(3,410 Views)
What C series modules are you using?  Or are you looking to buy one?  NI does have some relay modules you could just use instead of making up a bunch of circuitry.
(3,390 Views)
i am going to choose G2 RL-1A E DC 24V mechanical relay datasheet attached with post.To control the realy i have c series NI 9476 DO.can i use this setup for my application.
(3,336 Views)
