how to stop/pause an subvi from main panel control
Hi all
I am in need of a solution from you all.
in my code i need to stop the subvi from the main vi panel.
once i start my code control goes to the subvi which is Data Acquistion from DAQ card.
I need to stop/pause this data acquisition when ever i need. i tried with global variables or passing through reference but i couldnt succeed
Can anyone help me in this
thanks
Regards
Bala
Message 1 of 11
(3,780 Views)
Hi Bala,
It should work with a reference, don't use the globals.
Can you post your VI's so we can look at it ?
Message 2 of 11
(3,761 Views)
Hi KC
sorry i cant post my vi as it is a big one and also little bit confidential.
if you require i can make a sample of that and i can post here
with reference i am getting error.can u send me a vi with reference so i can have a glance
thanks
regards
Bala
Message 3 of 11
(3,753 Views)
VI 1 has a stop button and a led on the front panel. The value of the stop button is used to stop VI 1 and VI 2. VI 2 controls the led
Message 4 of 11
(3,751 Views)
Hi KC
Thanks for the vi. i tried the same but got a error before. now its working.
but i have another problem in this.i am using the same structure as u have made but inside the subvi i am using a case structure which also contains the while loop.the case structure is for DAQ card.i tried the same for that but i couldnt stop the while loop inside the case structure.
Thanks and regards
Bala
Message 5 of 11
(3,744 Views)
Hi Bala,
I don't see what the case structure has to do with your problem. Can you simplify your VI's and post them ?
Message 6 of 11
(3,741 Views)
You really need to post at least an image of your code. I'm guessing that you have the read of the value property node in the wrong place. It would need to be inside the inner most while loop.
p.s. Questions of this nature have nothing to do with DAQ and should be posted in the LabVIEW forum.
Message 7 of 11
(3,740 Views)
Hi KC
I have attached the screen shot with this mail.sorry i couldnt post the vi
this is inside the case structure of the subvi
like this i am using while loop in each case.
so when i press stop in main panel i have to pause the action doing here inside the case structure
this is a state machine architecture so case is inside the while loop
thanks and regards
Bala
Message 8 of 11
(3,731 Views)
Like Dennis said you placed the read of the property node outside the while-loop.
Also note that Dennis pointed out you post to the wrong board.
You also should keep good wiring aspects. The error cluster inside the while-loop going from right to left. I think you should use a shift register there.
and now I understand your hurry you only 30 days for your program.........
Message 9 of 11
(3,727 Views)
Sorry guys really i am in hurry tats why.
i have to edit the code.
but im trying for functionality first....
also i tried the both placing inside the loop. but i couldnt succeed in that also ok i will try again
thanks
Bala
Message 10 of 11
(3,701 Views)
