how to trigger a counter (for impulse generation) with a analog peak
Hi everyone,
I am getting mad with a simple task (for you),
I use a Ni USB-6251 with screw terminals.
I am trying to send to any adapted output a 0-5V impulse using an analog signal (external sampling with an angle encoder varying in the 6-18kHz range), which generates a peak at a frequency comprised between 5 and 25Hz.
The word file in attachment shows that it works quite well if generating a single numeric pulse.
Here is my problem: how can I convert this numeric pulse in a counter impulse which allows for setting a 'time' for low/high state and triggering the start of the impulse.
Can you help me?
Message 1 of 1
(3,799 Views)
