how to use 9264 card with cdaq 9172
hi
 i m using labview 8.6 ver. i have cdaq 9172. Now i want to interface 9264 card with cdaq 9172. how can i use . i m not getting what should i use daq assistant input or daq assistant output whats the difference b/w them.i tried both but it is giving error. i just wanted to on/offf a led on 9264 card.
(2,952 Views)
It's a 16 channel analog output so it would seem obvious to use the analog output option in the DAQ Assistant.
Since you did not provide the error code, it's impossible to say what you did incorrectly or what can be done to fix the error.
(2,949 Views)
