how to wire daq 6009
i am trying to count pulses with my daq 6009 but i dont know on which port i must connect the wires
pulses come from a flowmeter which feeds with 5 volts
can anyone tell me which ports i need to use?
Message 1 of 9
(5,065 Views)
Hi there,
Have a look at the specs here:  http://www.ni.com/pdf/manuals/371303e.pdf
Specifically,  look for the Event Counter.  The spec says: You can configure PFI 0 as a source for a gated invertor counter input edge
count task. In this mode, falling-edge events are counted using a 32-bit counter. For more information about event timing requirements, refer to the Specifications section.
Good luck!
Patrick Allen: FunctionalityUnlimited.ca
Message 2 of 9
(5,062 Views)
i did indeed connect it to the port you name, but is wasnt really working:(
i just need to translate my pulses tot a flow in labVIEW but it seems that no one can tell me how to do that
Message 3 of 9
(5,057 Views)
Why not start with posting what you have so far?
It will make it easier for others monitoring the boards to help you out.
Message 4 of 9
(5,050 Views)
well, i have a flowmeter wich has 3 wires, a plus and a minus which get 5 volts en a variable, which gives a pulse at each 16 millilitres
than i have the daq 6009 which following the specs has a counter en a have labVIEW 8.0
now i am a student at the higer technical school and my task is to translate the pulses to a flow which you can see as a gauge in labVIEW
today i connected the minus from the flowmeter to the ground on the daq en the plus to the pfi 0 port, that doesn't give any result on my daq program, so not even in labview yet
if i connect it to an analog port ai1 i see the blockwave in my dfaq program but i still cant read it into labview:(
i also have a pressure meter which gives a voltage between 1 and 5 volts to meassure a hight in a tank, this was no problem connecting and it words fine
Message 5 of 9
(5,040 Views)
Hi Thijsse,
Please notice the link below.
Bas
Message 6 of 9
(4,985 Views)
And in the usermanual you can find information about using PFI0 as event counter, see attachment.
Bas
Message 7 of 9
(4,978 Views)
I try to use the count of my NI 6009 with Matlab.
Explainations about PFI0 are really small...
How create the channel ? And how access the data ?
Eti'n
Message 8 of 9
(4,447 Views)
Hello Eti'n
Thank you for your post. I don't have any experience with Matlab, so I can't help you with that, but there is a tutorial and some tools which can help you to work with the driver (DAQmx), please review the following document and find the download tools below this page.
Martijn S
NI Netherlands
Message 9 of 9
(4,420 Views)
