i need to set high and low temperatures, which will set off a sound if passed.
I'm doing this on a DaqBook 2k0. I spilt the channels up and converted then into F. The readings are then shown on 15 bar graphs. I want to set this up on each channel (one at a time). I want to get the line of data (temp) for each channel on an High, low alarm. When the high or low is passed i want some kind of sound to be set off. I found that your samples used LabView hardware so they just linked into that.Using 3rd party i need to get the alarm to read the data, not device.
-Thank You
(2,408 Views)
VinnyC,
You should be able to use parts of the LabVIEW example programs, but you will need to replace the NI-DAQ VIs with VIs provided to you by your 3rd party hardware manufacturer. Please contact them for their LabVIEW driver and examples of how to use it. If you need help with non-DAQ programming to send an alarm, please post again in the LabVIEW category. Hope this helps. Have a great day!
(2,408 Views)
