import microVolt pressure transducer data into labview
I am planning to use a pressure transducer from WPI (http://www.wpiinc.com/index.php/vmchk/BLPR2.html). The sensitivity of this transducer is given as 5 microV/V/mm Hg. The company has an amplifier (cost $1800) that can be used with this transducer to amplify the output signal. However, I am wondering if I can directly collect the data from the transducer using LabView. Do I have to use an amplifier or does NI have an amplifier that I can use to collect my pressure data from the transducer.
thanks
N
(3,509 Views)
Looks like every bridge amplifier could do the job, HOWEVER  IF you want to use this sensor on humans you should carefully check the medical security standards !
Greetings from Germany
Henrik
LV since v3.1
(3,499 Views)
No, I am not using this on humans. I am using it in an experimental testing of skin tissue to monitor my pressure.
Does NI have an amplifier that I can use?
N
(3,486 Views)
Hello Maverick269,
I assume you need a bridge amplifier?
NI 9219 is a universal 24 bit cDAQ module that I think will work for your purposes. You will also need to buy a chassis for it, and then you can control it with a USB connection.
Maggie
ni.com/support
(3,469 Views)
