impossible to connect i/o device
Not found icona  on FUNCTION windows for conected i/o module from compacDAQ
(2,839 Views)
Can you find the connected device in the device manager of your PC?
If yes, can you find it using Measurement & Automation Explorer?
What is the name of your i/o device and what drivers did you install on your PC (can you find the drivers name in MAX under the voice software)?
(2,805 Views)
