indefinite waveform generation using AO Waveform Gen
I am trying to generate an indefinitely long waveform using the AO Waveform Gen VI (which should get cleared when I call AO Clear). I can get AO Waveform Gen to create a waveform of finite duration, by passing an appropriate input to generation count. But when I pass 0 to the generation count input, the output only updates once, and there is no waveform.]
Sumit
(2,569 Views)
Sumit,
Besides inputting a value of zero into the generation count input, you must also input a Boolean "false" into the clear generation input.
Good luck with your application.
Spencer S.
(2,569 Views)
