initialize I/O Pin
I am a new programmer, I got a question, hope get help from you.
How to initialize Pin I/O of NI 6036E, e.g. set PFI 9 Low or High in DAQmx ANSI C ?
(2,936 Views)
You would not use one of the PFI lines generally. What you are describing is Digital I/O functionality. You can find examples of how to do this on your own computer (if you have the DAQ driver installed). It should be located here:
C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\Generate Values
Anuj D.
(2,923 Views)
