04-26-2015 05:46 AM
I am using Windows 8, installed Labview 2014 Student Edition, then downloaded NI-DAQmx, however do not have any icons I expected to see in a YouTube video. My question is, how/where to obtain the respective DAQmx sub-icons?
Solved! Go to Solution.
04-26-2015 08:13 AM
What version of DAQmx did you install? Did you install DAQmx AFTER installing LabVIEW? Did you reboot your computer?
04-26-2015 08:30 AM
I installed DAQ version VDM 2013, and yes, I installed DAQ after installing Labview then rebooted computer.
04-26-2015
10:02 AM
- last edited on
10-19-2026
05:40 PM
by
Content Cleaner
There is no such version 2013. I have no idea what VDM is. You should install the latest to get support for LabVIEW 2014 - https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288236
04-26-2015 12:16 PM
I used the hot link and downloaded the most recent version of DAQmx as suggested, restarted both the computer & Labview, and the "Vision & Motion" shows up s before on my "Functions Pallete" of the "Block Diagram" window, however no icon are present when I select "Vision & Motion". Other thoughts or suggestions?
04-26-2015 12:30 PM - edited 04-26-2015 12:53 PM
I think I am trying to get the correct module to work. My objective is to convert the pixel RGB values of a camera's image file to CieLab color space coordinates, then obtain the mean, mode, std_dev, and a histogram of the each the three data sets. I found a link on the NI website indicating the IMAQ Color Processing Pallete has a function (i.e., Vision & Motion ->Color Processing -> ColorHistogram) that may very well do what I'm trying to achieve, but it indicates the NI Vision Development Module is required.
Thanks for the input,
04-26-2015 01:01 PM - edited 04-26-2015 01:02 PM
Please note, I have the "Student Edition" and not the "Student Edition Suite".
04-26-2015 02:22 PM
04-26-2015 08:49 PM
Thank you for the assistance with respect to the "Vision and Motion", the link to the lastest version works as you suggested.
04-26-2015 10:09 PM
