int32 CVICALLBACK EveryNCallback on gcc
I am configuring a code for continuous sampling using NI-DAQmx (6255). In the ANCI C sample codes, the following is used:
int32 CVICALLBACK EveryNCallback(...
Is this only for CVI environment or can I use it on gcc too?
Cheers
(3,212 Views)
(3,118 Views)
Nope, I have already generated the necessary library for the gcc compiler. I just want to know whether  " int32 CVICALLBACK EveryNCallback " works on gcc. I am not sure since it calls CVICALLBACK. I was able to compile the sample code. But I dont know if it will work fine with the device.
(3,081 Views)
CVICALLBACK is just a #define to (ultimately) tell the compiler to use the __cdecl calling convention:
#if defined(__linux__) || defined(__APPLE__)
#define __CFUNC
#define __CFUNC_C
#define __CFUNCPTRVAR
#define CVICDECL
#define CVICALLBACK     CVICDECL
#else
#define __CFUNC         __stdcall
#define __CFUNC_C       __cdecl
#define __CFUNCPTRVAR   __cdecl
#define CVICDECL        __cdecl
#endif
Assuming that gcc understands the __cdecl keyword it should work fine.
(In this context "CVICALLBACK" isn't specific to CVI, it refers to any C environment. The "CVI" prefix is present for historic reasons.)
(3,077 Views)
