interfacing DAQPad with DSP kit running TI RTOS
Hi
We have NI DAQPad 6251 with us and want to acquire the signals through visual studio and  TI RTOS "DSP/BIOS 6" running on DSP kit. Could anybody send the proper documentation, example projects and hardware connection details required for beginners.
Thank you in advance.
 With warm regards,
(3,393 Views)
There are multiple methods of programming with NI-DAQ or NI-DAQmx ( National Instruments Data Acquisition Drivers ) in Visual Studio. Please go throught the following NI knowledge base.
http://digital.ni.com/public.nsf/websearch/8715FD7608B79AFC86256ECA004B87F1?OpenDocument
http://digital.ni.com/public.nsf/websearch/AFFC0BE95DE6B38186256D9B0051342B?OpenDocument
Please find examples of using NI DAQ device with Visual Studio at the following NI Developer resource.
http://zone.ni.com/devzone/cda/tut/p/id/6999
Trust it helps.
Best Regards
Ankur
(3,386 Views)
Can I get simillar resourcs for DSP/BIOS RTOs from Texas Instruments?
How it will be different from Visual studio?
Prat
(3,382 Views)
I want to have APIs and port ID to send/receive signal through individual ports of NI USB-6251. Can any body help.
Prat
(3,366 Views)
Hello friends,
I want to know the registry and address for read/write, set sampling frequencies, voltage ranges etc. on the DAQPad  6251 so that I can sample and acquire the data through one of the dsp board. Also, what is the format of the data outputted at USB port?
Could you pplease provide suitable documents, sample projects for reference?
With best regards,
Prat
(3,355 Views)
