intermediate result display
Hi, I have an analog input task which slowly reads finite amount of data. I need to display intermediate results :
request N points
start
while all data not ready
    get what is ready (M pts)
    diplay what is ready (1st to M pts)
    wait a little
diplay all (1st to N pts)
clear
what is the best implementation of this protocol in ANSI C ? if i use DAQmxReadAnalogF64 do i need to append each ready chunk of data myself ?
Thanks!
(4,083 Views)
Hi Boris,
It depends on how you configure the DAQmxReadAnalogF64. The numSampsPerChan determines the number of samples, per channel, to read.
If the task acquires samples continuously and you set this parameter to -1, this function reads all the samples currently available in the buffer.
Take a look at this page and see if that helps answer your question:
http://zone.ni.com/reference/en-XX/help/370471W-01/daqmxcfunc/daqmxreadanalogf64/
(4,047 Views)
