is hardware timing is supported by the PCI 6251 card?
I am using the NI_DAQmx  ANSII c API .  I like to clarify whether the PCI 6251  card supports the hardware timing ?
(2,740 Views)
Yes, it does support hardware timing.
The basic capabilities of the board are:  16-Bit, 1 MS/s (Multichannel), 1.25 MS/s (1-Channel)  https://www.ni.com/en-us/support/model.pci-6251.html
No way you would get that without hardware timingSmiley Wink
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(2,728 Views)
