Currently, LabVIEW for Windows is not supported in Windows CE OS so you cannot do any LabVIEW development in Windows CE (even if you are using teh LabVIEW PDA module). However you can use the LabVIEW PDA module to build executables that would run in Windows CE.
I hope it helps.
Ankita A.
