learning to use TaskDoneEventHandlier with .NET
I'm having some difficulty closing (DIsposing) the task, to the extent that I cannot call my routine again.  I receive the "NI Platform Services, this resource could not be allocated" message.  I've tried to mimic the "GenMultiVoltUpdates_IntCLK" example without luck (i.e it doesn't deallocate the resource)..  Basically, the task does not get disposed.  What can I do to correct this?
My code is attached (its really quite short).  Assume that the double[,] array "waveform" was previously successfully created.  Basically, it always works the very first time but never on successive calls.  I sorely need help on the TaskEvent handler and Task.Dispose aspects.
 Please advise.  Thanks.  Anand
(3,682 Views)
Hi All,
It appears that the TaskDoneEventHandlier is not being invoked.
Since I'm calling it from within a function that I wrote (not a buttonClick routine),  is there a chance that its not receiving the right arguments (object sender, Evnetargs e) ?
If I could receive some assitance with this, I'll be really grateful.  I've yet to master events and delegates in C#.
Anand
(3,665 Views)
Hi All,
Instead of depending upon the TaskDoneEventHandler facility, it is also possible to poll the task in the following manner.
- - - - setup waveform
- - - - setup AnalogMultiChannelWriter
- - - - setup Sample Clock
myTask.Start();    // outputs waveform on multiple channels clocked by 'onBoardClock'.
while(! myTask.IsDone)    // wait till task completes
{  ;  }    // do nothing
myTask.Dispose();
This works fine and does not depend upon the TaskDoneEventHandler.
Anand
(3,659 Views)
