legacy DAQ in MAX Configuration window
I have LabVIEW 7.1, and in MAX under Software it indicates NI-DAQmx v8.8 and Traditional NI-DAQ v7.4.4. When I expand Devices and Interfaces, only NI-DAQmx Devices ppears with the DAQ board listed (PCI-6221: "Dev1"). The VI I need to ru uses the traditioal DAQ. When I run the VI I get an error message that the board needs to be configured. How can I get Traditional DAQ to apear in the Devices and Interfaces drop down so I can configure the board? The VI is not easily updated to DAQmx.
Thanks for any advice.
Paul
(3,001 Views)
Accepted by topic author Liberated
Hi Paul,
The PCI-6221 is an M Series board.  M Series boards do not have support for the Traditional DAQ driver.
Major Differences Between E Series and M Series DAQ Devices
Jim Schwartz
(2,986 Views)
Thanks for the article link Jim. I guess there is no time like the present to update this VI. I appreciate the help.
Paul
(2,981 Views)
