Hi all!
I'm experiencing troubles with daqmx 8.0 for linux.
When I do "nidaqmxconfig --export MyConfigFile.ini", the output is: "Operation successful.". Good.
Now let's do "nidaqmxconfig --import MyConfigFile.ini", the output is:
"Error -201042
Device specification provided does not match any hardware in the system.
Change the device specification to match a device present in your system. You can also change your device specification to be less specific.
Property: Name, PXI.ChassisNum
Line Number: 5
Status Code: -201042"
I really don't understand what's going on. Please help me!
My PC is connected to a PXI-1042 with MXI4. The PXI-1042 contains a PXI-6280 board.
nilsdev returns: "NI PXI-6280: "Dev1""
The hardware is OK, it works under Windows (I have a dual-boot). Please see the attached file, generated by nidaqmxconfig.
My linux distro is Red Hat WS4 (update1), running KDE. The PC is a DELL Dimension 8400 with 3.2GHz Pentium 4 and 1GB RAM.
Thanks in advance for your answers.
