locating and solving problem due to a high voltage input to DAQ
Hi! By mistake a high voltage was fed through input channel of my DAQ NI PCI-6052E. After that daq is not functioning(giving -10V measurement always). I use SCB-68 connector block with this DAQ card. I checked the connector with the output board pci6711 and found it was functioning. How can I trace out the location of the problem?
(2,461 Views)
Greetings,
My first suggestion would be to run the Online E Series Diagnostic Utility. This should verify whether or not your board is damaged and needs to be sent back to NI for repair. I have included a link to this utility below:
Spencer S.
(2,461 Views)
