long hardware responce only time during DAQ
I use visual C++ with "NI Measurement Studio" to connect (over TCPIP) with DAQ from HBM(MGCPlus).
Everything works fine, until i try to sample over 1 Hz.
Using sample rates over 1 Hz(2 or more), the Hardware does not responce any more. I used also cross-over cable with no effect.
The supplied software with this hardware works fine and there is no delay during DAQ.
I used the sequence of commands, which the HBM software uses for DAQ in my application. But just in my application sample rate over 1 Hz is not possible.
Message 1 of 1
(2,470 Views)
