matlab cannot recognize usb-6218 BNC
Hello, i want to output a signal of 5 voltages through usb-6218 BNC and i have connected the DAQ device to my laptop. However, Matlab(R2011a)doesn't recognize the device and shows'No data acquisition devices available'. Someone says that it is so because 6218 is not a compact DAQ. Is it the exact reason? What else should i do if i want to output a 5V signal?
(4,613 Views)
Hi there JJ.WIll!
My name is Max and I'm an applications engineer here at NI. T he issue might be that you do not have the DAQmx drivers installed. Could you please try downloading them from here - http://www.ni.com/download/ni-daqmx-14.5.1/5271/en/ then close down MatLab and reopen it?
Let me know if this solves the issue!
(4,562 Views)
