matlab engine disappear when save LV code first time
Matlab script nodes are embedded in my LV code. When I modify the LV code (whatever but not the math script in matlab script node) and save it for the first time, the matlab server (i.e. matlab command window) will disappear from the windows taskbar. Running the LV code at this time will popup error message because the matlab server is unavailable. Then I modify the math script (even simply add a space) in the matlab script node and save again (sometimes just click the TICK on the toolbar and save LV code), the matlab server (matlab command window) appears on the taskbar again and the labview code can run again. This two-step saving usually takes more than 40 seconds. I never met such problem before. Anyone and help me solve this problem?
Windows XP sp2 ,now SP3 :). LV. 8.0 (now upgrade to 8.0.1)
Thanks.
Message Edited by Mowr on 05-21-2008 04:04 AM
(3,131 Views)
This was reported to R&D (38141 CAR ID) for further investigation. R&D is currently investigating this issue. We appreciate your feedback!
Mehak D.
(3,118 Views)
