matlab with NI-usb 6008
hello,
I'm trying to connect the NI-usb 6008 DAQ with Matlab.
I've followed the instructions given in Matlab yet matlab cant load the adaptor for NI.
I've installed NI-DAQmx 8.6
the message that i keep receiving is :
daqregister('nidaq')
ans =
Unable to load adaptor: C:\Program Files\MATLAB\R2007a\toolbox\daq\daq\private\mwnidaq.dll.
Driver files or DLL for the specified adaptor could not be found or are not installed.
the dll is instaled.
the OS is vista
daqhardwareinfo =
          ToolboxName: 'Data Acquisition Toolbox'
       ToolboxVersion: '2.10 (R2007a)'
        MATLABVersion: '7.4 (R2007a)'
    InstalledAdaptors: {'winsound'}
i'll appreciate any help on the subject,
Moshe G
Message 1 of 18
(9,849 Views)
Do you have the National Instruments NIDAQmx drivers installed?  Can you see the device in MAX?  We have tested this device with VIsta 32.
-Rob
Rob Purser
Manager, Test and Measurement
MathWorks
rob.purser@mathworks.com
Message 2 of 18
(9,839 Views)
i've installed all drivers and it appears on MAX.
i'm also using vista 32.
we checked the device on another computer with XP sp2 and it works fine with Matlab.
Moshe
Message 3 of 18
(9,825 Views)
It sounds like the Data Acquisition Toolbox can't find your NIDAQmx drivers.  Check to make sure that the NIDAQmx DLLs are on your path.
-Rob
Rob Purser
MathWorks
Message 4 of 18
(9,820 Views)
i'm receiving this msg when trying to add the path:
"you cannot add method folders(ones that starts with '@')
or private folders to your Matlab search path."
i tried to change the folder name but it didnt do the trick.
Moshe
Message 5 of 18
(9,808 Views)
Sorry, I meant your system path, rather than MATLAB path.  You need to find where you installed the NIDAQmx drivers, and then check that the system path (type PATH at the command prompt) contains that directory.
-Rob
Rob Purser
MathWorks
Message 6 of 18
(9,806 Views)
the system path doesnt contain that directory.
how do i include that directory in the system path?
Moshe
Message 7 of 18
(9,805 Views)
Googling "adding to the windows path" will offer a place to start.  I can't offer exact steps in Vista.
-Rob
Rob Purser
MathWorks
Message 8 of 18
(9,801 Views)
Hi Moshegt
I would like to point some resources that have worked for Windows XP. Just confirm that you are not missing any step (probably similar for Vista) even though you are trying to install Daqmx 8.6 in Vista x86. Use M-Series cards with DAQmx in Matlab. This is the Mathworks web site for National Instruments support: Supported Hardware - National Instruments.
I hope it helps
Jaime Hoffiz
Product Expert
Message 9 of 18
(9,790 Views)
i've checked the system path on the XP computer were the daq works fine and it is the same as the vista computer. i dont know what to change next.
could it be related to the fact that matlab refuses to add a path to private folders?
Message 10 of 18
(9,775 Views)
