maximum current rating of DAQ 6009
I have to measure the voltage and current of Induction motor and feed it to the PC through DAQ 6009. I have used a voltage sensor 'LV20P' of maximum input rating of 500V. I have placed a resistor of 330 ohms in the ouput side of the sensor inorder to get output voltage of 7V. the corresponding output current from the sensor is 21.5mA. Is it possible to supply the current to DAQ 6009. What is the maximum current and voltage rating of the same.
(2,845 Views)
Duplicated post: see here
(2,828 Views)
