maximum frequency out on PCMCIA 6024E
Hi all,
I have a short question about the PCMCIA 6024E. What is the maximum frequency that I can generate on the counter out pin?
Thanks for the help!
Charel Marais
(2,899 Views)
The 6024E has a 20 MHz timebase on board. The counters on the 6024 work with two load registers for the number of timebase ticks the output should be high or low. The minimum value for both load registers is two timebase ticks. Thus the maximum counter output frequency is 20 MHz / 4 = 5 MHz.
I hope that helps,
Jochen Klier
National Instruments Germany
(2,891 Views)
