i'm using the DAQ 6221 card..
i want to measure the voltage from the analog input.. and show the measure in a chart
i'm using the attached example..
the problem is tha when i measure the voltage.. in the first time, it measurements are true..(my source has a voltage at 5V) but after it stop at 10V and don't do anything! y?
i tried and changed the mode from differential to RSE.. and i have the same problem..
how did i change the mode from differential to RSE?
i doubled click to the Daqmx Create Channel.. and then i changed the mode " input terminal configuration " from differential to RSE
is it true?
thanks a lot!!
andrikos
