measurement of resistance by USB 6008
Every program I run I get same error no matter what, I am trying in basic programs and still not working measurement from input channels. I don't know, may be is a cable issue or something? I have gone to MAX and in self-calibration gives me same error
Message 21 of 22
(866 Views)
Sorry, I can't open your vi ( I still haven't upgraded from my running LV12 system)
However, if you have access to the Sound and vibration suite/toolkit, you can try the Frequency response with Swept sine (DAQmx).vi provided with the examples. If you use differential input configuration for the voltage drop at your reference resistor and your DUT you only have to scale the result with your Rref value 🙂
Greetings from Germany
Henrik
LV since v3.1
Message 22 of 22
(862 Views)
