measuring frequency of analog input in DASYLab9
I have just started using DASYLab9 and I am trying to display the frequency of an analog input. Any suggestions?
(3,242 Views)
Hi Kanilammit,
One common frequency measurement used on analong signals is the Fast Fourier Transform (FFT). DASYLab has FFT analysis modules and the Help file explains more about what FFTs are and how to use them on a worksheet. The descriptions are in Help » Contents, then Module Functions » Module Group Signal Processing » FFT.
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(3,232 Views)
Thanks.
(3,230 Views)
