measuring velocity
For a school project, I am looking for a way to measure  velocity using the bnc2120 connector. What device would measure velocity and connect to the bnc2120 terminal block? THe vehicle i'm measuring the speed of is powered by a shrouded wind turbine, and can move directly in the wind. I need to measure the velocity of the vehicle and measure rpm of the blade.
(3,323 Views)
Hello amz23,
In order to best answer this question, I'm assuming you will be using a digital encoder to measure pulses to obtain angular velocity (in RPM) for the blade. If so, the NI BNC-2120 interfaces with our X Series, M Series, E Series, S Series, and NI 671x devices. These devices have counters e.g. to measure velocity (for example rotational speed of a shaft) you will need a signal proportional to speed, squared and in TTL/pulses standard to input to the counter. I have included a link (1) with more information on the BNC-2120 and a detailed list of the different device series mentioned above (see left pane of the page). To learn more about counters/encoders, see link 2 below of the M Series User Manual, Chapter 7 on Counters; or search "encoder" at www.ni.com for tutorials and LabVIEW examples on these measurements.
1. NI BNC-2120:  https://www.ni.com/en-us/support/model.bnc-2120.html
2. M Series User Manual: https://www.ni.com/docs/en-US/bundle/pci-pcie-pxi-pxie-usb-62xx-features/resource/371022l.pdf.
Ali M
Message Edited by Ali M on 04-12-2010 05:01 PM
(3,298 Views)
