multichannel daq - huge crosstalk
Hello all,
I am using the attached .vi to collect three analog channels simultaneously using NI-USB 6216. The problem is when I apply some voltage reference (e.g. 1 volt) to only one channel, all three channels show identical values (the same exact 1 volt). Also when I leave all of them disconnected they start decaying slowly to -5.320 volt.
I just need to collect three analog channels indepenedently. I appreciate your help on this case.
Thanks.
Amir
(3,180 Views)
Is your ground tied to AI Sense?  I've seen floating grounds do some strange things.
(3,176 Views)
@livelive wrote:
Hello all,
Thanks.
Amir
What you are seeing is normal with muxed inputs when some or all are disconnected. Do a search for 'ghosting' or 'crosstalk'.
(3,173 Views)
