myDAQ Grounding
I have a question regarding the grounding of my myDAQ device.
I am trying to use the device to control motor speed, using an inverter. The issue I am facing is that the device dies every time I try and connect any of the ground pins for the device to the ground for the inverter. Can anyone explain why this is happening?
Message 1 of 1
(2,650 Views)
