myDAQ & NI USB-6002- big delay between analog output and input on same device
Brief followup.  Attached is code I modified only to set the DAQmx property I mentioned.  Note that this won't change anything about your 1 second software buffer latency.   For that, you'd need a smaller software task buffer, writing fewer samples more often.
-Kevin P
Message 21 of 22
(410 Views)
Dear all,
Thank you for all your kind information and more suggestion on my issue. it provided more ideas to solve the problem.
I managed it by increasing the rate, which makes loop runs more fast than 1 s. as additional information, i use buffer input with higher than the used rate.
Message 22 of 22
(384 Views)
