myDAQ and NI-DAQmx Base with MAC OS X 10.10
Dear Community users,
I have just succesfully installed the myDAQ Driver in MAC OSX 10.10 and I can use the myDAQ via the "Test Panels" App.
Now I will to controll the myDAQ via C programms, so I try to get access to the myDAQ via the NI-DAQmx Base Dirvers and the C-Reference. I have just installed the NI-DAQmx Base 14.0 Drivers on my MAC OSX 10.10. When I lunch the "lsdaq" App it does not find the myDAQ Device.
My question is:
Is there any way to get access to the myDAQ via the C-Reference/Library of the NI-DAQmx Drivers ?
Thank you !
toeztuerk
(4,461 Views)
the DAQmx Base driver does not include the NI myDAQ as a supported device.
Unfortunatelly, the DAQmx driver for Mac OS is not available. Therefore it will be necessary to use Windows within bootcamp or a virtual machine like it is mentioned here (Using the NI myDAQ with Mac OS - http://digital.ni.com/public.nsf/allkb/6C8810E7E3712358862579C800528432) to use DAQmx C API.
Following properties are supported within DAQmx and myDAQ:
NI myDAQ Supported Properties
http://zone.ni.com/reference/en-XX/help/370471W-01/cdaqmxsupp/nimydaq/
This link could be also helpful:
Using NI-DAQmx in Text Based Programming Environments
http://www.ni.com/white-paper/5409/en/#toc3
Thomas
(4,399 Views)
Hi Thomas,
Do you know whether the driver for Mac OS X 10.10 is going to be avaible soon?
(3,870 Views)
