myDAQ vs USB-6008
Hello everyone! I am a student and I want to buy a DAQ for my personal use. After hunting down the net, I came across two DAQ devices that could meet my needs - NI myDAQ and NI USB-6008. All the features that myDAQ provides is also present in USB-6008 (some features can be used with LabVIEW). So, which one should I choose?
(5,001 Views)
Hi maxmiaggi
the hardware will depend on the type of projects you plan to do. the myDAQ includes a DMM, 200kS/s analog sampling rate, and access to 8 software instruments (Oscope, DMM, Function Generator, Bode Analyzer ect). Take a look here for more info http://www.ni.com/mydaq/.You can check with your local office to see if myDAQ is available in your region.
What types of tasks, projects do you plan to work on?
Mark
(4,976 Views)
Well, I am from India and myDAQ is available here. I basically want to use it for my personal use, like sometimes we get some mini-projects from the university, etc. I am also currently working on a project to build a humanoid. So I was also thinking to use it there on a short-scale purpose. So, what do you think, which one would be better for me, myDAQ or USB-6008?
(4,961 Views)
Hahaha, if you're going to build a humanoid, you'll need more than the myDAQ or USB-6008. 🙂
I think you should think through this question yourself a little longer.  Both units have specs online.
Personally I bought the USB-6008 since my main goal was for Labview training and such.  The myDAQ has the Audio input/outputs if I remember correctly which could be fun for some things.  I'm also considering creating an H-Bridge driver board to drive stepper motors and such, but that can be done with either unit I think.
Jason
(4,601 Views)
