need a wiring chart for (6122) m-series to cb-68lp
i am trying to hook up a 6122M DAQ to a CB-68LP terminal block.  I plan on using all 24 DIO available, so i need to see the chart
of which channels get wired for each input.  the reference chart i have is for E series with only 8 DIO.
(3,007 Views)
Check out this DevZone article about finding your device's pinout in MAX:
http://zone.ni.com/devzone/cda/tut/p/id/4053
This can also be found in the NI-DAQmx Help under "NI-DAQmx Device Terminals Help" (Start >> Programs >> National Instruments >> NI-DAQ >> NI-DAQmx Help)
Sal
(3,000 Views)
