ni daqpad mio 16-XE-50 on XP
I have a daqpad mio 16-XE-50 which I would like to use on XP
but labview doesnt have driver support after windows2000. also
do I have no control over the IRQ for the printer port (its an addon card),
is it neccesary to have a specific IRQ ( this is a parallel port card)
If anyone has drivers to share, I would appreciate it
(3,410 Views)
You are correct that there is no support for this device on XP.  The following links below may provide some insight into using the parallel port to print-hopefully this helps.
http://digital.ni.com/public.nsf/allkb/F1FA6AE18FC860778625702000591465?OpenDocument
http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB?OpenDocument
h_baker
(3,381 Views)
