ni-scope with ni-6229
Hi all,
I would like to know if I can use ni pci 6229 with ni-scope soft? I didnt find any information about that.
Thank you,
Dima.
Message 1 of 12
(5,231 Views)
No. You use scope hardware with NI-Scope and DAQ devices with DAQmx software.
Message 2 of 12
(5,229 Views)
what do you mean by scope hardware?
Message 3 of 12
(5,226 Views)
Message 4 of 12
(5,217 Views)
this is very expensive. I found something else: http://www.ni.com/virtualbench/buy/.
But interesting thing if I connect enter from functional generator into the ni-6229 I didnt see the signal? or I should build a program to see this?
Message 5 of 12
(5,212 Views)
You should be able to set-up the 6229 with the test panel in
MAX before you write a program.
Message 6 of 12
(5,200 Views)
Message 7 of 12
(5,197 Views)
So Dennis,
If its all right and my computer sees this card then I can write a program to determine the frequency of the signal and ect. But once again question: can I connect functional generation to the ni-6229 through the connector block?
Thank you.
Message 8 of 12
(5,196 Views)
I have no idea what function generator you are talking about but the whole purpose of the analog inputs of the 6229 is to measure physical signals so I don't understand why you are so confused. How did you make the connection?
Message 9 of 12
(5,190 Views)
you are right. it shouldn't be a problem to connect it. the functional generator is oor-x 311.
its a regular input of 50 Ohm. Anyway my goal is to measure a signals with ni-6229. I would like to write some kind of program to simulate a simple scope with that card. just to see the sinusoidal signals.
I made connections with BNC.
Thank you.
Message 10 of 12
(5,183 Views)
