ni usb-6009 galvanic isolation
I am currently working with measurement system of an electrical car at my University. I intended to use shunts to measure current of electric components with RSE input mode without grounding, transfer it over DAQ card (NI USB-6009) to PC in the car, and to monitor these measurements in Labview.
So I am asking: does the NI USB-6009 card provide galvanic isolation for current signals? So the PC couldn't be harmed if overcurrent or overvoltage somewhere in the car system occurs.
Thank you in advance.
(3,424 Views)
The USB-6008 doesn't have isolation.
The most similar isolated device would probably be the USB-6215.
(3,416 Views)
Consider Hall effect sensors such as the Allegro Microsystems ACS756 in place of shunts.  They have lower burden than shunts and up to 3 kV isolation.
Lynn
(3,405 Views)
