ni usb-6351 task
we have a mesurement problem with an ni usb-6351 which we experienced in the MAX.
If I measure using single virtual global channels they work fine.
However if I use a daqmx task for 10 channels, the returned values are false.
I attached my Fekpadconfig.nce configuration file, but with a .cfg extension as posting did not accepted the .nce extension !
I use MAX 4.7.1f8 and DAQmx 9.2.
I have no idea, what could be the reason of that, I never experinced similar before.
Sincerely, Balint Juhasz
Hungary, Budapest
(3,279 Views)
Hi Balint,
I have tied to reproduce the behaviour.
Firstly, I chose "Add Global Channels" when I created new task. In that case the added virtual channels didn't inherit the input mode (Terminal Configuration), they bacame differential inputs.
Secondly, I chose "Copy Global Channels" and I was able to change Terminal Configuration mode to RSE and others.
Could you try to remake your task with copy global channels option and try to measure again?
Peter
Peter Vago
(3,241 Views)
