ni9225
Does the NI9225, 3 Channel 300Vrms Input Card supports 2.5 sq. mm.? If not, could you suggest any viable alternative solution?
(2,899 Views)
Hi Anish.Babu,
According to the Datasheet. The NI9225 module suports AWG gauge wire between 16 and 28, which means a maximum of 1.31 sq mm and a minimum of 0.081 sqmm gauge wire. It should be possible to replace the current screw terminals with larger gauge terminals, as they are removable. I will look into it and post back to you.
Ben B.
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
(2,848 Views)
Hi again Anish.Babu,
I have spoken with my colleagues and it seems that curently we do not sell screw terminals that can accomodate a larger gauge wire for that particular module. If you wanted to you could either use a 16 gauge wire, or convert your 2.5 sq mm into a smaller gauge. If you want to discuss your hardware needs your local office will happily assist you. You can find contact details for all of our offices at ni.com/contact.
Best Regards,
Ben B.
(2,839 Views)
