niScope_SetAttributeViReal64 returns Attribute ID not recognized for NISCOPE_ATTR_TRIGGER_IMPEDANCE attribute
Hi all!
Here is the code:
rc = niScope_SetAttributeViReal64 (
this->sessionId, VI_NULL, NISCOPE_ATTR_TRIGGER_IMPEDANCE, triggerImpedance);
It's supposed to work I guess...
What can be the problem?
(3,420 Views)
Hello Babay,
Which Device are you using?
This feature is only supported by NI 5112.
Attached you can find a screenshot from the NI Help.
If you are using the NI 5112, are you also getting an error number?
Stefan
(3,410 Views)
I'm sorry I forgot to write here that I've already found the answer. Yes the problem is that I'm using NI5114. Thank you anyway.
(3,404 Views)
