nidaq32.dll and nidex32.dll missing from nidaqmx 20.7
I tried to use my c++ software, which uses nidaqmx c api functions defined in NIDAQmx.h to win 10.
I installed the latest nidaqmx 20.7
My program fails to start because it cannot locate nidaq32.dll and nidex32.dll
they are not shipped with nidaqmx 20.7
I thought that the dll implementing the NIDAQmx.h functions are just those nidaq32.dll and nidex32.dll
Any suggestions?
(3,574 Views)
Accepted by topic author Renttu
Hi there,
This seems like a common issue, I have found a couple of forum discussions with similar topics:
https://forums.ni.com/t5/Multifunction-DAQ/nidaq32-lib-amp-nidex32-lib/td-p/1699206
https://forums.ni.com/t5/Digital-I-O/can-t-find-file-nidaq32-dll/td-p/463449
I recommend you to check them and if they were not helpful let us know 🙂
(3,510 Views)
Thanks, problem solved!
(3,503 Views)
