nidaqmx AnalogUnscaledReader data type as unsigned int
I'm writing a python script to read "raw" AI data (in continuous mode). Right now I'm using a PCI-6361 board. I got it to work using the AnalogUnscaledReader. However, from trial and error, I found out that the data is int16. I have two questions.
First, how could I automatically detect in code that the data received from the card is signed int 16? On the (opened) AIChannel, I found ai_raw_samp_size = 16, and I assume that's how I'd know it's 16 bits (and not 32 bits). However, I cannot find any indication that it's signed or unsigned. Is there any attribute for that?
Next, is there a way to actually request a different format to the card? I would actually prefer to read the data as uint16 (because that's how I have to save it, so that would save a conversion step).
For reference here is my current code (which works fine, but it's stuck to reading int16's):
DEVICE = "Dev1"
def read_ai_cont(channels: List[int], sample_rate=float,
                 should_stop=threading.Event, q=queue.Queue):
    buffer_size = min(1_000_000, int(sample_rate * 0.1)) # Enough for 0.1 s
    # Generate the channels names. It's just a comma separated list of [device]/[channel]
    # ex: "Dev1/ai0,Dev1/ai4"
    channel_names = ",".join([f"{DEVICE}/ai{n}" for n in channels])
    with nidaqmx.Task() as task:
        task.ai_channels.add_ai_voltage_chan(channel_names,
                        terminal_config=TerminalConfiguration.DIFF,
                        min_val=-5.0,
                        max_val=5.0,
                        units=VoltageUnits.VOLTS
        task.timing.cfg_samp_clk_timing(sample_rate,
                                        sample_mode=AcquisitionType.CONTINUOUS,
                                        samps_per_chan=buffer_size, # In continuous mode, indicates the size of the buffer
        reader = AnalogUnscaledReader(task.in_stream)
        task.start()
        while not should_stop.is_set():
            # TODO how do we now it's int16? (and not uint16 or int32?)
            # TODO how to change the device to read as uint?
            data = numpy.empty((len(channels), buffer_size), dtype=numpy.int16)
            data[:] = 0
            reader.read_int16(data, number_of_samples_per_channel=buffer_size)
            logging.debug("Acquired one buffer")
            print(data)
Best,
Éric
(1,251 Views)
Accepted by topic author pieleric
According to nidaqmx._task_modules.in_stream — NI-DAQmx Python API 0.7 documentation, since you specify a negative to positive input range, the device will return an int.
https://tmesystems.net/
(1,234 Views)
Thanks a lot for pointing to that code. That seems to explain it.
I've looked further, but still couldn't find any way to force the DAQ board to return a different type? (I'd like to get unsigned, even if the voltage of the board is actually -5 -> 5V)
Also, do you know if that's the same for the AO raw type? For this, I actually care less (because I can generate whatever pleases the board), but it'd be handy to know in advance, instead of doing trials and error!
(1,220 Views)
I believe that you cannot change this behaviour. You can do a post-processing and add an offset to cast the int16 to uint16 but you have to remember that you make the change.
I am not sure about this. Since both ADC and DAC on PCIe-6361 are 16-bit, I guess that they will use the same data type.
(1,207 Views)
