nidaqmx driver installation on ubuntu 22.04
hi
I'm trying to install driver nidaqmx (version 22.08) on ubuntu 22.04 ,but not get installed successfully.
showing some errors that I hv mentioned. is there any possible solution for the same.
libnipalu.so failed to initialize
Verify that nipalk.ko is built and loaded.
Aborted (core dumped)
(3,692 Views)
Hi Sree07*,
Unfortunately, there is no any attachment, share with picture or write an error code to be clearly.
Make sure that have installed NI Linux Device Drivers.
And also, follow this link to make the installation in appropriate way.
Regards)
________
The best way to show appreciation for someone's help is to give them Kudos or mark their response as a solution.
(3,640 Views)
Based on my previous experience, those errors usually happened because "sudo dkms autoinstall" is forgotten.
https://tmesystems.net/
(3,632 Views)
