nidaqmx for win 7 starter on netbook
this problem is on a netbook with ms 7 starter.
states that it does not support nidaqmx.
need a solution for a client so we can run app. on usb 6008.
thanks
Jim
7709831369
jrf@aeverl.com
qmasys@mindspring.com
(3,513 Views)
Hello Jim,
Thank you for using NI forums.  What version of DAQmx are you using.  Since Windows 7 is a newly released OS only our lastest DAQmx driver supports it.  NI-DAQmx 9.0.2 now has added support for Windows 7.  Please let me know if you are still encountering problems.
(3,472 Views)
The NI Installers do not currently support Windows 7 Starter. The only current work around is to use a supported distribution of Windows 7, DAQmx 9.0.2 will not install either. Can your client move to a machine with a supported OS?
Andrew S
(3,462 Views)
